Changing my phone number by Porting another number?
salomon N.
Posts: 8 ✭✭
Since my new job will be paying for my cell hpone i will be transffering my Phone number from Fizz to the New compnay but i want to keep the monthly plan i have with fizz and transfer in another phone number. Can that be done?
11
Good question. You should ask Fizz support directly.1
Thanks for the question1
No you cannot, you can have a new plan, paying the actual price1 -
I believe you can change your number in your profile. When i first got my random number with Fizz I was able to keep the plan and change to a new phone number1
Unfortunately that can't be done. As soon the number port is complete the Fizz line is cancelled and if you were on the Beta pricing you will automatically lose it. Maybe you can ask your Employer for a new phone number1
