How strong is Fizz's signal in two storey houses?
manal T.
manal T. Posts: 1 ✭✭
Is Fizz internet effective in big houses? If not, what should I install to have good signal everywhere in the house?
  • Samuel C. 64723
    Samuel C. 64723 Posts: 166 ✭✭
    The Fizz modem/router can be sufficient for a single level. For multiple levels, I would recommend buying a wifi booster/repeater.
    That’s what I am using in my home. Works quite well :)
  • LemonHead
    LemonHead Posts: 355 ✭✭
    I would recommend a repeater. If you have an old router you can usually use them as a repeater. You'll just have to do research if you don't know how to but it's pretty simple in most cases.
  • Yelena
    Yelena Posts: 1,861 ✭✭
    Fizz modem-router works fine for me without any extender. I put it in the middle of the first floor, and the signal is good on the second floor as well.
  • Victoria C. #24523
    Victoria C. #24523 Posts: 367 ✭✭
    Big houses always require several modems to be effective. Fizz is no exception
  • Ajaykumar
    Ajaykumar Posts: 91 ✭✭
    My old router was strong enough for 2 story but Fizz provided Wifi router is not strong enough. I would recomend you to use a seperate router with stronger signal strength
