What are the rates of the mobile addons?
George S. #20091
Posts: 639 ✭✭
in My Mobile
I don't have a mobile plan so I'm not able to see the rates of addons:
- Travel add-on
- Data add-on if I'm out of data during the actual month
How can I see these rates without having a mobile plan?
- Travel add-on
19
You cannot see them without the mobile plan14
As mentioned, you need a mobile plan to see the latest rates.
The data rates look like this and they are subject to change17 -
Thank you! Fizzy,
for your information14 -
You have to log into your account and go to manage plan, then in the add on section you will see prices14
Good question thank you9
The rates depend on the country you are in, they are more expensive in some places and less expensive in others. The add-on section will provide you with the answer for your current location and you can look online for other locations.9
Interesting question, I also wanted to see all the rates!9
