What kind of Coaxial cable does Fizz uses?
Wizard
Wizard Posts: 1 ✭✭
I want to buy a longer coaxial cable, what kind is recommended for maximum performance?
    Mike Posts: 20,727 ✭✭
    If you have a short length the cable is not so important for the attenuation, since you will lose more on the connection
    I will use an RG6
  • Alexander Y.
    Alexander Y. Posts: 288 ✭✭
    I have never even heard of a world coaxial... I always thought cables are wily her black or white. Well, I guess there are always althings to learn eh
    MichelP Posts: 8,733 ✭✭
    Wizard,
    You can buy Rg6, coaxial câble in many stores.
  • Olivier R. #3666
    Good cables my firend.
