Is data blocked on a plan that does not have data?
steve H. #28578
Posts: 1 ✭✭
in My Mobile
I don t want unexpected charges
22
Yes, if you do not have data you cannot use it.
However the exception is if you put money in the Fizz’s wallet9 -
Hi Steve,
Fizz is always prepaid. You have to pay for the service up-front before you can use it.
There are never unexpected charges or surprise bills.10 -
Thanks for the question8
Yes that is correct. Even if your phone tried to use Fizz data, the Fizz network will not give it any (until you get a plan with data or purchase a data add-on)8
Sorry, just thought of another point. If you have no data plan, but use your house wifi (or any other wifi) then your phone will connect to the internet using wifi. IT STILL WILL NOT use any Fizz data.
Just thought I'd share that too :-)8 -
Steve,
Fizz is a pre-paid service. Only, you decide...
If you do not have data in your mobile plan, you cant use it.
And you wont pay for it.
However, if you buy an add-on of data, you'll be able to use it.2
