Does Canada plan cover texts and calls from Cda to USA while I'm in Canada or would I need to take a
Looking into possibly transferring to fizz mobile. Montreal, QC resident. Does a Canada plan cover texts and calls from Canada to us while in Canada or would I need to take the Canada-US plan?
Also, can we change plans as needed? example if I go to the United States (FL), Can I change for the Canada-US plan with extra data temporarily and return to my Canada only plan with less data once I return. We are snowbirds so will spend up to 4 consecutive months in the United States.
24
Hello mtrom62.The canada plan will not allow you to call to Us you will need an add-on for that. You can see them in your account and choose one.Or you can choose the canada Usa plan.
You can change your plan when you want 48 hours before the renewal date.
You have one conditions
We reserve the right to interrupt or block access to our network of partner providers Fizz EXT if you use your mobile service primarily on their networks for 3 consecutive payment cycles.
Source: https://fizz.ca/en/faq/partner-networks
So for 4 months you will not be able to use fizz...just for 3 months.
Everything here..https://fizz.ca/en/solutions/search?keys=roaming6 -
Yes !4
