I traveled to another city and my mobile internet doesn't work anymore, eventhough my plan was supposed to work in the whole country.
Hello Mariana,
Apologies for the encountered issue.
Have you verified if the area you are currently in is within the green or pink zone? If the area you are in shows up with gray on the map, we do not have roaming partners in there. You can verify the region you are in here:
If you are in a non-gray area on our coverage map, please try a power reboot for your phone, then head over to settings- Networks- mobile network and slide off the automatic network search and wait a few moments, then select a Fizz EXT network available and test. A few more helpful tips can be found here:
https://fizz.ca/en/faq/how-do-i-use-my-phone-to-access-th...
If the issue still persists, please reach us by chat.
Have a good day.
Catalin
Make sure "Data roaming" is set to Allowed on your phone.
Hi Mariana,
After Data Roaming is enabled, if the problem continues, you can put your phone on airplane mode for 1 minute. Then retry.
I've already done both things and it doesn't work.
Try another phone and check if the problem persists
Which city did you go? Yes les others said, try data roaming.
Could you check on your plan you if have canada enabled?
Did you consumes all your data? Did your credit card declined a payment? There are many thing that can stop you having your internet.
Mariana,
Please check this map for Fizz's mobile coverage area
https://fizz.ca/en/coverage
Also make sure you have the same APN settings on your phone and you have not changed them
If it doesn't work, here's how to contact customer support by chat, from 8 AM to 9 PM everyday:
