Do the upload speed of 10 mbps can be improved?
Charles L. #21853
Charles L. #21853 Posts: 12 ✭✭
Is it the only option?
    Mike Posts: 20,751 ✭✭
    Yes with the 120Mbps plan, you can have 20 Mbps
  • Victoria C. #24523
    Victoria C. #24523 Posts: 367 ✭✭
    You can definitely upgrade it, not sure what the problem is?..
  • SuperFizzeur
    SuperFizzeur Posts: 3,777 ✭✭
    Hi Charles.
    The maximum upload speed right now is 20mbps with the 120mb download speed.
    Fizz have asked some customers about need speeds, but we don't have the information right now.
    have a nice day,
    It's been a pleasure.
  • SuperFizzeur
    Hi Charles!
    Have you got your right answer :)?
    MichelP Posts: 8,733 ✭✭
    Charles,
    Yes, if you choose the Fizz internet plan of 120 mbs/20.
    The upload is 20 mbs.
