If I uninscribe & then reregister immediately, do I get $ credit back to use right after?
Michael F. 60500
Michael F. 60500 Posts: 1 ✭✭
I want to port my Rogers cell number to Fizz. Unfortunately, I activated my SIM without 1rts porting the #, One of the 2 options available is to deregister my new Fizz Acc.and then port my old # during the re-registration process which is OK for me, but do I get full or partial credit to my registered account?
    Mike Posts: 20,747 ✭✭
    Non because is not considered a trial
    Probably it will work if you unsubscribe and ré-registre with a new email
  • Damek G.
    Damek G. Posts: 151 ✭✭
    @Mike
    Why do you always write «non» instead of «no» ? you do know that « non » in english is «no» right?
    Edit: i’m assuming you’re using a french keyboard and that in this case you meant «none».
