Connect to Blu-ray?
Anyone know how to connect your modem to a samsung blu-ray player? I've connected the ethernet cable to the modem and blu-ray and I have entered everything manually. When i do the internet test it tells me that my 'gateway ping' is not connecting.
When i try it the auto connect everything connects but then I get a message that my HTTP port isn't connected....
Please help! I'm not very tech savvy...
9
Did you try to update the blu-ray firmware?2
Hi Farana,
normally it's suppose to connect automaticaly.
Contact the manufacturer or read the manual to have more informations.
It's been a pleasure to assist you today.
Sincerely, Matt.
Don't hesitate to mark my answer as the best.1 -
Problem resolved?0
