Referal code application for Home Internet plan ?
Franck M. #26305
Posts: 1 ✭✭
in Internet
Where can I enter my friend's referral code in order to create my Home Internet plan ?
14
You should find a field in checkout when you see the amount of your plan where you can enter a referral code.7
You can also have your friend send you a referral link and sign up through there. It will store the code in the URL and then your session and you should see it automatically pop-up in the checkout process
If not right before you pay there should be an option to apply a code.7 -
Hi Franck.
There a form field case to enter the promo refferal code from your case when subscribing to internet.
Have a nice day5 -
Franck,
When you desire to order to a subscribtion for Fizz internet, there is a form field case appearing to enter a Fizz referral code after you have chosen the speed of your plan.5 -
Thanks for the question3
You can't use a friend's referral if you already used for your mobile service.
If it is your first time, pls, check the 2nd point.
https://fizz.ca/en/faq/how-do-i-invite-friends-to-join-fizz2 -
Hello Franck,
I have verified and you already created an internet plan, also you entered the referral code. The referral bonus will only appear once both parties (you and your referral friend) pay TWO billing cycles.
As our Community members suggested, the field where to enter the the referral code is just right before the final confirmation.
Thank you, have a great day!
Adelina2
