Do you guys have any tips to speed up the voicemail?
Daniel C. 52837
Posts: 4 ✭✭
in My Mobile
I find the operator takes way too long. Is there away for him to either speak faster or to remove certain options? Any solutions are welcome.
7
Yes skip the message with the key #6
Type "1" as soon the voice is starting, you will go to the message. 3 to skip a part of the message.5
Hi Daniel!
You can speed up voice mail by pressing the touch "1".
It's been a pleasure to assist you today. If you have any further questions don't hesitate to ask.
Don't forget to mark this answer as the best answer!2
