Poor signal strength in Lachine, Quebec area
Did you try to force the use of a different network operator?2
Maybe shift to Fido could be a better idea1
There seem to be a few outages in lachine today. You can check this to see if it is a permanent problem or just a temporary problem.
https://istheservicedowncanada.com/status/videotron/6545041-lachine-montreal-quebec-canada2 -
Hello Bo,
I apologize for this unpleasant situation you encounter while you were traveling to Lachine.
As Mike suggested, try to manually connect to any of our partner's networks, shown as Fizz.EXT on your phone's settings.
If the situation persists or you are not able to make use of your services, please contact our support department, which can be found over the link https://fizz.ca/en/contact-us
Nicolae Bogdan2
