Alexa in car?
lucasjobin
Posts: 1 ✭✭
in My Mobile
Can Fizz allow calls from Alexa in car?
15
Hi lucasjobin, i believe it should it's a phone line just like aby other company. As long as you manage to connect your phone via bluetooth to Alexa you should be good. Hope this helps!3
Hi lucasjobin you should be able to it has to do with your phone normally not the line. As long as your bluetooth can connect to Alexa it should work for you1
I don’t know1
Hi LucasJobin! Thanks for your fantastic question.
No fizz can allow calls from alexa. You need to configure alexa properly to have calls.
It's been a pleasure to assist you today. If you have any further questions don't hesitate to ask.
Don't forget to mark this answer as the best answer!1
