My intetnetvis cut , what should i d
Seyed S. #14957
Seyed S. #14957 Posts: 2 ✭✭
There is some brick works are being done on my building and my internet line is cut, what should I do?
    Mike Posts: 20,641 ✭✭
    It can be a false contact, therefore, when they touch or move a cable you will lose the signal.
    Contact the support, since if you have the problem with the cable, they should send someone to fix it.
    2- Click on this link: https://fizz.ca/en/faq/my-modem-connected-cable-my-connection-keeps-cutting-out-how-do-i-fix
    Whizz Posts: 18,805 admin
    Hello Seyed,
    Apologies for the encountered issue.
    Please reach us directly by chat with photos of the cable in order to assist you with this matter. You can use the link Mike provided in order to do so.
    Have a good day.
    Catalin
