add on on my fizz plan ?
I need help putting on my plan 4GB of data in my fizz plan they are only giving 2GB not enough
    Mike Posts: 20,747 ✭✭
    You need to buy the 2GB addon twice
    Do you know that you can ask here for a gift
  • Anne-laure F.
    Anne-laure F. Posts: 584 ✭✭
    Hi Jose !
    If you need more data on a regular basis, i suggest you update your plan : https://fizz.ca/fr/forfait-mobile?ADDONS[0]=18&CVRG=108&DATA=99&PLAN=1&SMS=223&VOICE=90
    If you want to use add-ons, you have to buy it twice.
    Don't hesitate to give me a heart and/or mark my answer as the best if it was useful to you.
    Have a great day ! :)
  • Jambonneau
    Jambonneau Posts: 148 ✭✭
    Hi Jose,
    As Mike said, try with the community first, people here are very generous,
    Just to ask for it in a question, it worth giving a try before buying add on.
    Regards
  • SuperFizzeur
    SuperFizzeur Posts: 3,777 ✭✭
    Hi Jose! Thanks for your fantastic question.
    In your case i suggest to try to get data from others members or by buying some data add-ons.
    It's been a pleasure to assist you today. If you have any further questions don't hesitate to ask.
    Don't forget to mark this answer as the best answer! :)
  • Alexandre P. 40143
    Alexandre P. 40143 Posts: 204 ✭✭
    Login in your account after go in PLANS go to MANAGE PLAN after go in ADJUST PLAN an finally CHANGE PLAN
  • Olivier R. #3666
    Pay and add data
  • Sylvieb
    Sylvieb Posts: 1,623 ✭✭
    I hope your problem is solved. Can you please choose your best answer.
    Have a good day.
