Need some data?
Hi Elaine, the timer will not reset for the recipient and the Gifted Data will be used before the usual Data Plan. Any remaining Data will rollover on the next billing cycle. Have a great afternoon !!4
Hi Elaine! Thanks for your question!
Gifted data is valid until the end of the recipient’s payment cycle that follows the cycle during which the data was gifted. For example, say I receive gifted data on May 15, but my payment cycle ends on May 27. That gifted data will therefore be valid up until the end of my next payment cycle on June 27th.
It's been a pleasure to assist you today, if you have furthers questions i'm here to answer!
Have a great day and don't hesitate to mark my answer as the best.4 -
Yes, i need some.
I'll right you my number private.
THX a lot3 -
No, but you know, if this 6GB is about this current month, it will be add in your data plan for the next month...
You can rollover your not used data for 2 months.2
