Password problem every month?
sabrina B. #23804
Posts: 1 ✭✭
in Internet
Every month since I’ve gotten fizz (this is month 4) my wifi stops working. Everyone gets booted off and when we try to get back on, it says incorrect password. This happens every month for several hours. Usually it happens in the evening, and by time I wake up next morning, it’s back to normal- without me having done anything. Any ideas? It’s really starting to get on my nerves.
11
It can be a faulty modem or some updates
You should contact the support to let them know
here's how to contact customer support by chat, from 8 AM to 9 PM everyday:
- Connect to your Fizz account (if you have more than one, connect to the one that has the problem) by clicking « Login » in the top right corner at fizz.ca
- Click on this link: https://fizz.ca/en/faq/my-wi-fi-network-cutting-how-do-i-fix-it
- The green chat bubble should appear after a few seconds in the bottom right corner.
Do not hesitate to mark this answer as the best3 -
There is probably something wrong with your modem. You should contact customer services by chat, Messenger or Facebook.3
Hello sabrina,
I apologize for the situation that you've experienced.
As Mike said, please check the FAQ he provided and if the situation persists, don't hesitate to reach out to our support department so that they can have a look at your modem connection.
Cheers!
Nicolae Bogdan2 -
Hi Sabrina!
In your case i suggest you to contact directly a fizz support rep by clicking the green chat bubble
In your account dashboard or by facebook under the name fizz!
It's been a pleasure to assist you today! Have a great day!
Don't hesitate to mark my answer as the best!0 -
Hi Sabrina!
To follow your question. Your problem is resolved?0
