How to Create a Second Home Network
mathieu D. 54713
Posts: 5 ✭✭
in Internet
Hello I recently had to factory reset my modem and while trying to re-establish my home networks and I am seemingly no longer able to run multiple networks. Has there been a software change removing this? as I cannot create new networks through the app or router
5
What do you mean by multiple networks?
You can also connect the modem using the browser
192.168.0.11 -
(LAN): Links two or more devices using a wireless distribution method, providing a connection through access points to the wider Internet. Also please don't post my IP address on a public board.1
The class 192.168 is a private IP millions of people have it
https://en.wikipedia.org/wiki/Private_network
LAN means Local Area Networks it does not means WiFi
If you tell us what you need it will be easier to help you out
If you did a factory reset you should configure it again, follow the instructions that you have received with the modem
Here the instructions
https://fizz.ca/en/faq/how-install-my-wi-fi-modem1
