Data usage in British Columbia with a Quebec Plan
Mohammed-Nasser
Mohammed-Nasser Posts: 3 ✭✭
I have a plan with 4 GB of data and my coverage is limited to Quebec.
Can I use mobile data if I travel to British Columbia? Or do I need to buy Travel Add On?
    MichelP Posts: 8,733 ✭✭
    Mohammed-Nasser,
    Yes, you need to buy an add-on if you want to travel in B-C.
    Perhaps , it can be cheaper thatthat you change the coverage of your plan for the time of your travel for the Canada coverage and after, your return, take again the Quebec coverage.
  • SuperFizzeur
    SuperFizzeur Posts: 3,777 ✭✭
    Hi Mohammed-Nasser! Thanks for your wonderful question!
    You can use mobile data on a B-C Travel only if you change your plan to Canada or if you buy a travel add on!
    It's been a pleasure to assist you today! Have a great day! :)
    Don't hesitate to mark my answer as the best! :)
