how do i connection to wifi?
Can you be more precise? If you move and you need an appointment you can do it in your plan it should have an moving option somewhere. If you need to connect yourself to the wifi you speed to us trough some internet connection ? You can google you type of device and how to connect to wifi in google.6
Hello Kadisha,
Can you clarify your question. What is the missing cable? From the modem to your computer or from the wall to the modem?6 -
Hi Kadisha!
Please give more details...
Have a great day!!3 -
im sorry for you good luck2
