If I activate my 500mb does it use it before my “regular data”?
Daniel P. 53829
Daniel P. 53829 Posts: 21 ✭✭
I still have a decent about of data left but my 500mb has a couple days left to activate it. If I activate it will it be used before my “regular” data. And yes I do understand that there is a 30 day time limit to use it
  • lsabelle
    lsabelle Posts: 710 ✭✭
    Hi Daniel,
    Yes, your perk should be used first because your "regular data" are valid for 90 days.
    Your perk is valid for 30 days so it should be used first.
    Anyway, if you are about to lose it you are better activate it... Or give it to somebody.
  • Elizabeth B. #5037
    Elizabeth B. #5037 Posts: 80 ✭✭
    If it expires first, then yes.
