ubereats does not work with my number ?
When I try to get into ubereats with my mobile using fizz sim card it does not work ...
it need to send a text message to my phone but to get a code but i never receive one
text work with other provider and friend who are local
Robert
Robert
Robert
Level
point
Fizz had problem with the 2fa via SMS I suggest you to do it via an app like Google authenticator or Micosoft authenticator. It is more secure than SMS 2fa base and it will avoid this problem.
Did you find this useful ?
No (0)
Yes (0)
Hi Robert!
Have you check in your spam if u have android! Yes there is a spam folder in text message on android device! Second option try to contact directly Fizz By Facebook! :) Third and last option: try to contact ubereats!
Have a nice day! It's been a pleasure to assist you!
Don't hesitate to mark my answer as the best ! :)
Hi Robert
In the past fizz had this kind of problem.
The best option is to contact the support and let them check
here's how to contact customer support by chat, from 8 AM to 9 PM everyday:
1- Connect to your Fizz account (if you have more than one, connect to the one that has the problem) by clicking « Login » in the top right corner at fizz.ca
2- Click on this link: https://fizz.ca/en/faq/i-cant-send-or-receive-text-messages
Do not hesitate to mark this answer as the best
SittingRam
SittingRam
SittingRam
Level
3
2899 / 5000
This glitch seems like a reminder from Fizz's first days. I hope you are able to set-up your ubereats in another way
Olivier
Olivier
Olivier
Level
3
3839 / 5000
It's so bad for you
