Can we Wireless Distribution System (WDS) with Fizz Modem?
Johny A.
Johny A. Posts: 12 ✭✭
I want to have two separate Private LAN connection by adding two additional router to my existing Fizz Modem/Router. Does the Fizz Router has Wireless Distribution System (WDS) option like most of TP-Link routers? Thank you.
  • SuperFizzeur
    SuperFizzeur Posts: 3,777 ✭✭
    Hi Johny!
    Just connect to your router configuration by typping fizz router ip address then set it to bridge mode!
    It's been a pleasure to assist you have a nice day! If you have further questions don't hesitate to ask.
  • Olivier R. #3666
    Good question ,. And yes you can
