Is it possible to set a longer voicemail PIN?
If you google "voicemail security vulnerability length" you will discover that 4-digit voicemail PINs are highly vulnerable and because many services (including banks) use SMS messages and/or phone calls to authenticate money transfers hackers who break into your voicemail can essentially take over your banking accounts.
Can FIZZ please add the ability to set a longer voicemail PIN for those of us who want to? 6-8 characters would be much better. Again, I don't want to force a longer password on everyone, but we should at least have the option to set it if we wish.
Gili
Gili
Gili
Level
Whizz
Whizz
Whizz
Level
5000 / 5000
Team
Hello Gili,
I appreciate your concern about your privacy and for this suggestion.
I will send it to the respective team that handles our suggestions and the privacy to have a look at it.
Thank you for bringing it out.
Cheers!
Nicolae Bogdan
Did you find this useful ?
No (0)
Yes (0)
