Wifi down?
Not for me, here internet is fine and works speedily!!!4
Hello Alex,
I am sorry to hear that you've lost your Wi-Fi connection.
After I've checked your connection from our end, I could see that you have a good amount of devices connected and all are working on your wi-fi, however, for the current speed that you have, this amount of devices will slower or make your modem to freeze.
Therefore, I suggest you disconnect some of them or increase your plan speed.
I also suggest you have a look at the following FAQ https://fizz.ca/en/faq/my-wi-fi-network-cutting-how-do-i-fix-it for additional information and steps to follow.
If the situation persists, I suggest you contact our support department that can be found over the FAQ https://fizz.ca/en/contact-us.
Cheers!
Nicolae Bogdan4 -
@Alex,
In my area st-léonard is ok right now, because yesterday at 3:02 PM my internet was down and I contacted the customer service and they confirm me there was a problem in my sector, after 1/2 hrs the internet was back.
Check with customer service https://fizz.ca/en/contact-us. or you can use facebook chat https://facebook.com/fizzca
Regards
Mo2
