how to reach level 5?
Anne-Tso
Posts: 11 ✭✭
how long did it take you to reach level 5 and what are the steps to it? i noticed i reached previous levels very quickly.
19
Level 5 is 15000
Therefore depend from your partecipation, I believe if you partecipate to the community you will be able to reach in couple of months16 -
thanks for the quick response, will do that now!13
We must not forget that the bonuses only last 2 years after their activation so you must be able to pick up others for the rest !!11
It takes Mike-like perseverence, mike-like reflects and speed and mike-like knowledge8
Do like you are doing now, ask questions, answer questions...this all gives points.
By only giving kudos (hearts) you get 20 points per day.
50 points for every month you are part of the community
You get 3 points when you answer a question.
You get points for paying your bill
And if your answer gets selected as "best answer" you get more points. It all adds up pretty fast.15 -
continue to participate in the forum. Bit by bit you will reach level 5 in no time6
Keep participating in the community!3
I also found out that if you give your extra data to another member in need gave a pretty good amount of point!
Be nice to others it always works!2
