I forgot my wifi code? How do I reset my wifi code?
Diainet
Diainet Posts: 1 ✭✭
How do I reset my wifi code, I can't remember it?
  • Nathan
    Nathan Posts: 477 ✭✭
    Start with Sari idea, if not then Mike's is the way to go:)
  • redhead
    redhead Posts: 818 ✭✭
    Diainet, if you have your answer, time to select a "Best Answer" and close this discussion.
