is my device is compatible with fizz network?
I did not find a lot informations, however, it seems that it is not compatible with the Fizz Lte
https://fizz.ca/en/faq/compatible-devices12 -
You need to find the specification with your model and see your phone can use the B4 band that Fizz use for LTE4
