Connected Devices Not Visble
Rohan R.
Rohan R. Posts: 18 ✭✭
Why can't I see wireless and wired connections and their IP addresses.
  • Robert-John
    Robert-John Posts: 8 ✭✭
    Make sure you are not using any ad blocking extensions. Brave for example has ad blockers, and privacy controls built in and enabled by default. I would reboot the modem, connect to it directly through wire and try with a clean install of Firefox to see if it works.
  • AntonioMar
    AntonioMar Posts: 788 ✭✭
    have you tried to restart?
