Question about my new Wi-Fi
Gyovanna
Gyovanna Posts: 1 ✭✭
I just got the wifi at home and my appointment is On Wednesday and will I see someone to install my internet or will they send the modem by post office?
    Mike Posts: 20,751 ✭✭
    The technician will came test the signal if you already have the cable or install the cable and he will give you the modem
    MichelP Posts: 8,733 ✭✭
    Gyovanna,
    A technician will come to your appartment will bring your modem and will check the signal of your connection.
    sman Posts: 4,319 ✭✭
    Mike gave you the answer
    The tech must check the signal if you have already a cable or he will install it
    and it will leave the modem
    However you must not be in quarantine!!!
  • AntonioMar
    AntonioMar Posts: 788 ✭✭
    If u or somebody in your house is sick advise the tech first!!!
  • Hugo_R
    Hugo_R Posts: 438 ✭✭
    Make sure that you see the solid Internet light before the technician leave
