Can i cancel my plan for 2 months since I am not going out?
Sohele
Sohele Posts: 1 ✭✭
I want to cancel the plan for 2-3 months, for the duration of the lockdown, but I want to keep my number when I reactivate my plan.
  • Hugo_R
    Hugo_R Posts: 438 ✭✭
    Remove all the options on your plan and you will pay the minimum 10$ fee. But be careful, if the price as increased you will be charge higher if you modified you plan.
