Internet is not working, always get cut off,restarted many times, have to work from Home due to Covid 19?
Internet cuts off all the Time and then it's connected but no internet. WiFi is not working also to use Ethernet Cable.I have to work from Home and I need proper Internet.
Carl
Carl
Carl
Level
point
Did you already try to do a factory reset?
If you want to re-enable the Wi-Fi capability of your Fizz Wi-Fi modem, you'll need to reset it to its factory settings by holding down the reset button on the back of the device for ten (10) seconds.
Also try to
Disable Band Steering in Wireless -> Basic Settings -> 5G
Disable ATF in Wireless -> ATF -> 2.4G and 5G
Manually set the WiFi channels to the less crowded ones (see the answers in the other threads you made)
if this does not help try to contact the support
Try with this instructions, I tried now and I was able to have the chat bubble.
  • Go to this page https://fizz.ca/en/contact-us, if you are not connect login
Did you find this useful ?
No (0)
Yes (0)
Contacting support might be a good place to start it can be the videotron network in your area.
MgFizz
MgFizz
MgFizz
Level
3
2003 / 5000
Hugo_R
Hugo_R
Hugo_R
Level
2
895 / 2000
Try the reset, but I also think that the Internet is not so stable right now.
Hello Carl,
Checking your account I can see that you've contacted our support department and they've provided you the answer related to your situation.
If the situation persists or you need updates or encounter any other situations, don't hesitate to contact us by following the FAQ https://fizz.ca/en/contact-us.
Nicolae Bogdan
