Stuck at home due to COVID-19 Coronavirus?
FizzFanTim
Posts: 86 ✭✭
in My Mobile
Don’t forget to reduce your data plan if you can. Seeing lots of people online complaining about not using their data plans but still paying for them with other less-flexible carriers.
26
You must also say, if you modify your plan, be careful you are going to pay the actual price, and you can end up paying more.16
Fizzyfantime.
It's a risk that you are taking when you change your plan.
You will pay the regular plan at this moment.16 -
Probably my message was not clear
Since MichelP fill the need to repeat it :P14 -
Agree with Mike13
Hello FizzFanTime,
Thanks for this reminder. I am noticing this too with other providers.
Glad for the advantages of Fizz: plans can be modified month-to-month, data rollover and data gifting.15 -
I agree with Mike and Fizzy, think it well before to do change to your plan !12
I would use this extra data. Coronavirus already costed me 2 data add-ons and I still have 20 days left10
The price of your plan might change after the change.9
I agree, we are using only wifi and the mobile data will go to waste.
It would be nice if Fizz let current clients change the plans during the months that COVID will force us to work from home and still honour our current prices when it's over.
I concur what Mike mentioned about ending paying more, now is risky to change as we don't know when it'll be over (May? September? 2021?), we can't plan anything.7 -
Definitely recommend to check the price before and after - as Mike said, the longer-term users have better prices for their mobile plan than someone who would activate a new one today. It may be beneficial now if it's less but may end up being more expensive when you put back to the amount you had before. Good luck!2
