keep my old phone number. can i? and how?
trang H. #19199
trang H. #19199 Posts: 1 ✭✭
i lost my phone and just purchased a new one. i want to keep the old phone number but don't have its SIM card
  • Gogle
    Gogle Posts: 80 ✭✭
    contact costumer service
  • Damek G.
    Damek G. Posts: 151 ✭✭
    Hi Trang,
    I’m presuming that you’re already with FIZZ.
    If not, my answer should still cover you as it’s basically the same thing.
    First off, make sur your new phone is unlocked.
    Then, you are going to want to order another SIM card from Fizz.
    Once your SIM arrives by the mail, you’re going to follow the steps to activate it.
    When doing so, like I did, you should have an option to transfer an old phone number. Note that you will need to have kept your other line activated before hand if you wanted to transfer your number.
  • Hugo_R
    Hugo_R Posts: 438 ✭✭
    I guest you can.
