No range in my office with my Note 5. If I switch to GSM it's great (Fizz ext), but no data and can'
Emil T. #18736
Posts: 1 ✭✭
in My Mobile
I have impossible range in my office with my Note 5. If I switch to GSM it's great (shows Fizz ext), but no data and can't text. Settings? Allowing roaming didn't help. Adding APN IPv6 neither. What might be the contact number for ext SMS?
17
Flush the apn settup ans rebbot : some phone doesn't work with apn settings from fizz like my samsung s76
Did you check if your model is full compatible with the Fizz network?
https://fizz.ca/en/faq/compatible-devices6 -
Emil,
Have you checked if your phone is compatible with the Fizz network?
Also, try to reboot your phone.6 -
Hello Emil,
Please verify in your phone has the APN and SMSC configured as they are presented on our site. Once you have done so, do perform a quick reboot to your device and make a few tests to see if the issue persists. If yes, please go into your phone's settings menu-> Networks and connect to a Fizz EXT option for a few moments and switch back to Fizz once the option is visible and make a second test.
If the issue persists, please reach us directly by chat.
To verify your APN and SMSC, please consult the links bellow. The chat bubble should also appear in the bottom right corner.
https://fizz.ca/en/faq/how-do-i-use-my-phone-to-access-the-internet
https://fizz.ca/en/faq/i-cant-send-or-receive-text-messages
Catalin6
