i need help?
wrong order the title!
    Mike Posts: 20,751 ✭✭
    Can you elaborate?
    Or contact the support here we are users
    CHAT
    • Go to this page https://fizz.ca/en/contact-us, if you are not connect login
    FACEBOOK
    CONTACT FORM
  • Mo A.
    Mo A. Posts: 234 ✭✭
    Could you explain more, what is wrong
    Regards
    Mo
    MichelP Posts: 8,733 ✭✭
    If you need help,
    Please, contact the Fizz support by chat.
    The chat on line is available from 8h00 to 21h00. each day.
    The adress is;
  • SW_Sk8
    SW_Sk8 Posts: 95 ✭✭
    What seems to be the issue.
  • Felix D. #15236
    Felix D. #15236 Posts: 88 ✭✭
    Can you rephrase your question please, I'm not sure I understand.
  • Pascal L. 40582
    Pascal L. 40582 Posts: 649 ✭✭
    We don't understand your problem. Maybe you can translate to english using Google Translate https://translate.google.com/
    我们不了解您的问题。 也许您可以使用Google翻译https://translate.google.com/将其翻译成英文
  • Flo_B
    Flo_B Posts: 151 ✭✭
    very simple.
  • jeffstp
    jeffstp Posts: 81 ✭✭
    What a guy can do to have more points
  • Diane B. #16450
    Diane B. #16450 Posts: 26 ✭✭
    ok, you got help!
  • Olga P. #15146
    Olga P. #15146 Posts: 719 ✭✭
    @jeffstp ohhh maybe!
