Any custom OS (compatible with Fizz) recommandations?
Marc-Andre J. #18072
Posts: 2 ✭✭
in My Mobile
Hi everybody,
I've try some custom OS (like LineageOS, Resurrection Remix, Pixel Experience, and somes others I don't remember) and they were all not able to connect to Fizz network.
With them I was not able to enter manually the infos for the Fizz Network APN.
Since then, I've reinstalled the original ROM for my Samsung A5 (A520W) 2017.
Is there any friendly OS that's working with Fizz? I'm asking just for fun, thank you
24
Unfortunately, I don’t think so!6
Interesting question Marc-Andre.
I'm also curious to see the answers you'll get.7 -
Cynogenmod ROM was used by OnePlus, I don't know this is available or non
Hope this help
Regards
Mo7 -
SEGA Dreamcast Fizz support now!8
don't thinh so4
I've been using these custom ROM on a few different phone without any problem with Fizz Network. I was able to edit, add APN setting manually without issue. I have setup a Nexus 5 using LineageOS, OnePlus 1 using LineageOS, LeEco Max2 using RR, Pixel Experience, Redimi Note 8 with RevOS...All are using custom ROM and no issue with Fizz Network.5
I think any ROM should work with Fizz. The important thing is that the phone works on Fizz bands!6
HadesRom Pie Stock v1.5 ROM is working very well on Fizz with the Samsung SM-A520W.3
Try this config.
https://youtu.be/kovBCLVRayI
It on my oneplus 7t but I look into my pixel 2 and it is the same
Go under setting, network and Internet, mobile network.
Hope it helps you.
Which version are out using now?0 -
