Receiving voicemail text messages from Fizz when no voicemail is left?
jeff S. #13322
Posts: 1 ✭✭
in My Mobile
Problem persists daily. How can I turn off VM without affecting my current plan?
20
If you do not have a special price, you can remove it from your plan.
If you have a special price you should remove the call forward the calls to the voicemail
https://fizz.ca/en/faq/how-do-i-set-up-call-forwarding
You need to evaluate what will be better for you8 -
Jeff,
For the problem about your voicemail, did you ask for assistance from Fizz support?
Do you have a special price for your plan? If yes
Please, contact them.
Fizz chat support is available from 8h00 to 21h00, each day.
To chat with Fizz without problem:
First, open a session and access to your Fizz account.
Then, open a second window and type the adress:
Wait a few seconds to see the green chat bubble down to the right of the page.
When you see it, click on it.
Your chat session with Fizz begins.8 -
Nothing to add, Mike gave you the perfect answer4
