How much rewards for payments?
Martin G. 42829
Posts: 9 ✭✭
How much points do we get? I know about the community's points, but I didn't see for the rest.
23
I believe Fizz gives 10 points for every dollar spent on a plan.
These points do not apply to the forum points, only your account rewards.
6 -
Every cycle you pay for your plan you will get 10 points per dollar paid unless your bill was covered with a referral credit. Check your rewards points right before and after your cycle is done, you should see an increase.6
That give 1 point for every 10c after taxes and 10 points for every 1$ spend after taxes.4
Martin,
You get 10%.
For example: For a plan with tax of 34$: you get montly 340 pts.4 -
The right answer it is 10 pts x $
and not 10%
or 1 pts par 1c
Therefore, the first 2 questions are corrects6
