Do I have to call to cancel my old mobile plan?
Do I have to cancel my Vidéotron mobile plan that I had before registering to Fizz or do I have to call myself?
Since they switched the number already ...
I think I read that for Internet you need to call, but for mobile?
    Mike Posts: 20,751 ✭✭
    For the mobile, If you port (transfer) your number to fizz, no you do not need to contact videotron. You can check a week later in your online account to be sure, but you do not need to do so.
    For the home internet yes you need to do that, since you can have both.
  • André L. #16536
    André L. #16536 Posts: 647 ✭✭
    The "old" provider will normally close the old account and issue a credit if there was any pre-paid amount.  It is the same approach for mobile service as well as residential service.
  • JessicaRen
    JessicaRen Posts: 12 ✭✭
    You don't need to call to cancel your plan, as your number has already been ported. However, if there is a balance on your phone with your previous carrier, you will be charged the balance of the phone on your last bill.
