APN settings for iPhone
Why do you want to change your APN manually on your iphone? When you put the sim card, it does not work by itself?3
No, it's automaticly set when you update your iPhone's ios3
You can change the vpn settings yes
Fizz sends you the vpn settings automatically once you put the sim card in the phone.
Follow this guide if you need
https://www.truphone.com/support/how-to-configure-your-apn-settings-apple-ios/5
