Does anyone is having issues to accessing to Websites and having to perform the Cloudflare "I'm not
Diego G. #4438
Posts: 2 ✭✭
in Internet
A few days ago I started to notice a message from Cloudflare asking me to perform "I'm not a robot" checking. After investigating more I found the whole Dynamic IP range which I'm part is blacklisted under RATS-NoPTR.
"RATS-NoPtr is a collection of IP Addresses that have been found sending an abusive amount of connections, or trying too many invalid users at ISP and Telco's mail servers, and are also known to have no reverse DNS, a technique often used by bots and spammers."
That's an issue from Fizz, I expect that will be fixed soon.
The IP/Mask in question is 147.253.53.XXX/25
21
Contact Fizz support. maybe they can check why your IP is in a blacklist1
Sounds like an issue only Fizz can resolve. Contact support to see if they can help you.1
Diego,
I would recommand you to contact the Fizz support by chat about this..
You can contact them from 8h00 to 21h00, each day.
the adress is:
https://fizz.ca/en/contact-us1 -
Personally when I have a problem, I communicate with Fizz by messenger, that’s what works best for me.Good luck with this issue.1
No, never had that problem, I suggest also to contact Fizz support to help you with issue during working hours at:
Never encountered this problem either, best to speak with Fizz1
Maybe a robot had your IP before you. You maybe be able to get a new IP by disconnecting your modem for a certain period of time, but I don't know how long that period is. Good luck2
Hello Diego,
Thank you very much for all the info. I can assure you all that we are looking into it and we will keep you updated regarding this situation.
Have a good one!
-Bogdan1
