someone is stealing my wifi connection how to resolve ?
Someone somehow has access to my wifi, I can see the connection status through the Fizz app, the device isn't mine, other than changing my wifi password ( 2nd time he/she connects to my wifi ) what can i do , to whom should I speak about this issue or is there someone I can call.
Thx
    Mike Posts: 20,727 ✭✭
    Change your password, it is your only option
    If you want to chat with the support
    CHAT
    • Go to this page https://fizz.ca/en/faq/resolving-issues, if you are not connect login
    FACEBOOK
    CONTACT FORM
  • poker85
    poker85 Posts: 1,052 ✭✭
    Indeed, changing the word pass as well as changing the name of the network can help.
  • Meowth
    Meowth Posts: 94 ✭✭
    change your password for something harder to find (do not put your adresse) :)
    MichelP Posts: 8,733 ✭✭
    Bernard,
    First, change your password for a more difficult one to find.
    And ask for advice to the support of Fizz.
    Please, chat with them.
    This service is available from 8h00 to 21h00, each day
    The adress is:
    https:/fizz.ca/en/faq/resolving-issues
  • FizzFanTim
    FizzFanTim Posts: 86 ✭✭
    Unless your password is “password” or you are a person worthy of targeting (Prominent business owner, activist, or you have a jilted ex), I doubt someone is hacking into your internet repeatedly. Most likely you’re forgetting just how many devices one person has. Sensors, lights, game consoles, and cameras on top of the laptops, smartphones, and tablets.
  • GBy_6B8OA
    GBy_6B8OA Posts: 503 ✭✭
    change your admin password
    on 2.4GH and 5Gh WIFI BAND
    select WPA-Personnel security mode
    select WPA2-PSK (best) or WPA-PSK Auth Mode
    Seelct AES Encrypt Mode
    Disable Enable Guest
    in 5.3 The Wireless: Access Control Screen select the Block Rules
    you can stop a specific mac address
    change wifi password
    change admin password
  • Ari M.
    Ari M. Posts: 112 ✭✭
    Block traffic for that specific mac address in Wireless: Access Control Screen. And change your password, it always helps...
  • JC7
    JC7 Posts: 227 ✭✭
    Also if you find who is cracking the password of your WiFi and accesses your internet connection tell him that it is a crime in Canada. He may be a neighbor.
  • SW_Sk8
    SW_Sk8 Posts: 95 ✭✭
    Change your password a make it difficult including upper and lower cas, numbers and characters.
  • Chris K. #7521
    Chris K. #7521 Posts: 486 ✭✭
    Just change your password as others mentioned.
  • Benoit D. #9220
    Benoit D. #9220 Posts: 284 ✭✭
    Change password or block
