If i am only paying for Quebec coverage in my mobile plan, will i still be able to receive calls from Ontario numbers?
dan
dan
dan
Level
Did you find this useful ?
No (0)
Yes (0)
Vincent
Vincent
Vincent
Level
2
882 / 2000
Yes, incoming are free.
You will get ALL incoming calls REGARDLESS of where they come frome, AS LONG AS you are in the province of Quebec.
Also, note that with Fizz, you will receive all SMS - FOR FREE - REGARDLESS of where you are.
The important thing to remember about coverage is what service you expect when your phone is inside my coverage plan or outside of my coverage plan
When your phone is inside my coverage plan (QC in this case), then you are entitled to all the features within your plan (calling anywhere in QC, data working on your phone, receiving calls regardless from where they come from, etc.).  Think of it like in ancien times (when I was young), we used to have "long distance" charges.  People who called us never paid long distance charges.
When you phone is outside of my coverage plan, when basically nothing works (except for 911 calls in Canada - that's a CRTC rule :-)  ).
Hope this helps!
Claudia
Claudia
Claudia
Level
2
1082 / 2000
you can receive calls from anywhere as long as you are within your zone when you receive it.
Chris
Chris
Chris
Level
5000 / 5000
Yes of course. You wont be able to make calls TO Ontario or make calls FROM Ontario, but anyone can call you so long as you remain in Quebec.
