Does unused data from my perks rollover?
RitaVrataski
RitaVrataski Posts: 7 ✭✭
after the perk is in use
  • Toe
    Toe Posts: 60 ✭✭
    Perk only has 30 days life, I believe it move on within 30 days
  • Chris K. #7521
    Chris K. #7521 Posts: 486 ✭✭
    no it doesn't
  • André L. #16536
    André L. #16536 Posts: 647 ✭✭
    Nope.  It's only a perk and meant to be used within the same billing cycle.
  • Anthony I. #889
    Anthony I. #889 Posts: 31 ✭✭
    Nope, the perk'll just expire.
  • Benoit D. #9220
    Benoit D. #9220 Posts: 284 ✭✭
    Not works after
