How long did it take you to reach level 3 ?
hc0468
hc0468 Posts: 168 ✭✭
Level 3 at 4500 points is significant because it unlocks the second upgrade slot. It is also attainable relatively quickly, considering that the following level comes at 9000 points.
What is a typical amount of time among users, or at least forum participants, to reach this milestone?
