Trick to have the Wifi Faster?
Olivier R. #3666
Hello,. Anyone can share tips and tricks to have the Wifi Faster?
  • Felix D. #15236
    Felix D. #15236 Posts: 88 ✭✭
    Don't use wifi USB dongles, on your computers use internal WiFi cards with antenna if possible.
    sman Posts: 4,307 ✭✭
    For the fast wifi use the 5G
    If you need to have a better coverage this is another story
  • Chris K. #7521
    Chris K. #7521 Posts: 486 ✭✭
    Use the Fizz hardware as only modem, then get a WiFi 6 router.
  • hc0468
    hc0468 Posts: 168 ✭✭
    If you get a Wifi 6 router... you also need WiFi 6 devices to benefit from it. So, replace all your devices? ^^
    Using proper configuration even with WiFi 4 (802.11n, wireless N) would be more effective than just throwing money at the problem.
  • André L. #16536
    André L. #16536 Posts: 647 ✭✭
    When possible, avoid Wifi all together and hard-wire your network :-)  Cat 5e everywhere!  :-)
  • Vincent D. 39366
    Vincent D. 39366 Posts: 214 ✭✭
    Do you mean receiving the router faster, or making your current router faster? Changing the frequency of the wifi router can work, and changing its position too. Otherwise, unfortunately you have to reserve a time slot. You can always try contacting Fizz here to see if they have a way they could speed up the delivery: https://fizz.ca/en/contact-us
  • hc0468
    @André This is the internet, of course you will find Cat everywhere, can't be avoided. ^^
    But yes, go for ethernet whenever possible, Cat 5e, 6, 6a...
