I cant connect my Printer to wifi
salem H.
salem H. Posts: 2 ✭✭
I Joined FIzz recently , every thing works well except my Epson WIFI printer
    Mike Posts: 20,731 ✭✭
    Usually this is the problem with the band steering, the two band having the same ssid.
    you need to deactivate it
    https://fizz.ca/en/faq/my-wi-fi-network-cutting-how-do-i-fix-it
    The modification of this option is possible thanks to the mobile application Fizz Wi-Fi:
    1. Choose: ''My Wi-Fi''
    2. Select your Wi-Fi network
    3. Select: ''Advanced Settings''
    4. Band Steering ''On/Off''
     The Fizz Wi-Fi app is available for free at various online stores (Apple Store and Google Play Store).
    1. Log in at: 192.168.0.1 from the web browser of any device.
    Username: cusadmin
    Password: xxxxxxxx (Password you chose during initial setup)
  • hc0468
    hc0468 Posts: 168 ✭✭
    Try rebooting the printer. Sometimes it is needed for it to get recognized on a changed network.
    Aside from that, did you check the basics such as if it is connected to the wifi, and if it got an IP?
    MichelP Posts: 8,733 ✭✭
    Salem,
    Try to desactivate the band-steering like Mige has suggested you.
    sman Posts: 4,305 ✭✭
    Salem, did you try to disable the band steering, check the Mike guide
  • Olivier R. #3666
    Sorry my friend , good luck
  • Jimmy N. #14505
    Jimmy N. #14505 Posts: 620 ✭✭
    did you try to plug it in first ?
  • Kevin .
    Kevin . Posts: 50 ✭✭
    Salem , do what Mike say , he is the king of answers!
  • Chris K. #7521
    Chris K. #7521 Posts: 486 ✭✭
    Try what others suggested, if you are still having problems use your own router.
  • vanigh
    vanigh Posts: 328 ✭✭
    Please let us know if any of the suggestions worked for you, for community's benefit.
  • Toe
    Toe Posts: 60 ✭✭
    First you need connect printer by either USB cable, or wired connection. And you run Epson utility to configure printer (downloadable from epson website). And you can configure it .
    If you need help, go to youtube and find some tutorial.
