Will my phone work in Las Vegas? How much is the cost for using it? I need for 4 days?
And how to activate it.
Amikumari
Amikumari
Amikumari
Level
point
Mike
Mike
Mike
Level
5000 / 5000
You need to buy a travel addon or put money in your wallet
Go on your plan -> manage your plan -> Travel
Type Unite states and you will see all the options
If you pick, pay as you go, you need to fund your Fizz's wallet
For data remember to enable the data roaming option
Did you find this useful ?
No (0)
Yes (0)
In your plan, you have travel part, go in after you can add minute, data for price ( las vegas= USA)
EX: 500mb = 10$, 60minute=4 $.
Have a nice trip!
Amikumari,
You can buy add-ons for data, textos or call before your trip or add some money in your wallet but it's more expensive at usage.
Or buy a local sim in Las Vegas too, it can be an other good option.
Amikumari,
If your trip is only for 4 days in Las Vegas,
Before your trip, buy some add-ons (data, textos or call) for your needs in USA.
Have a wonderful trip!
sman
sman
sman
Level
3
3908 / 5000
Yes if you will travel next billing cycle and the renew is more than 48h, your best option is to switch the coverage
Amikumari,
Your phone will work in Las Vegas. Activate roaming.
And buy trip-add-ons for United states.
Go into your account online.
Click: Manage my plan
Also, click: Trip
Type: The country, you will visit
Then, make a choice of add-ons you needs.
And: confirm this trasaction
OmarAlsh
OmarAlsh
OmarAlsh
Level
If your coverage area (the zone you selected when you created your plan) includes the US, then you don't need to change anything. If it doesn't, you have a few options:
1. Switch your plan to include the US, although this wouldn't be practical since you are only there for 4 days. Remember that you must do this before your next cycle, so if your trip falls on your current cycle, this won't work. You can do this from the My Plan section by clicking Manage.
2. Add an Add-on for the US on the Fizz website. This will be under My Plan and Add-ons. This is the most viable option.
3. Buy a travel SIM when you arrive. This will require you to temporarily swap out your SIM or use dual-SIM. This would probably be the cheapest option.
Have a happy trip :)
André
André
André
Level
3
3142 / 5000
Remember, what happens in Vegas, stays in Vegas :-)
Amikumari,
Once you are login, click on the green button on the right to 'My Plans' then Travel link.
Here select United States of America
then chosse your option
Olivier
Olivier
Olivier
Level
5000 / 5000
take the USA monthly plan.
Concordia
Concordia
Concordia
Level
1
195 / 750
Yes. Your phone will definitely work in Las Vegas.
We were in Spain last year and just got the travel add-on for the duration of our vacation.
You can either go that route or switch to the plan with US coverage. Both are good options so you dont lose either way
Vincent
Vincent
Vincent
Level
2
896 / 2000
As others have said, you can purchase an add-on for 4 days, but it might actually be more economical to purchase a travel sim card, like a roam mobility card. If you look into it, their website is pretty easy to use, and you can reuse that sim card on future trips. That's what I do, as it tends to be much cheaper than using your regular carrier.
minayou
minayou
minayou
Level
Better switch to US coverage plan
